Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 7
You can now lift the speedometer assembly out, carefully. Note that there are wires that cross behind the gauge face; you will need to clear these wires to remove the gauge. You can now lift the speedometer assembly out, carefully. Note that there are wires that cross behind the gauge face; you will need to clear these wires to remove the gauge.
  • You can now lift the speedometer assembly out, carefully. Note that there are wires that cross behind the gauge face; you will need to clear these wires to remove the gauge.
Jetzt kannst du die Tachoeinheit vorsichtig herausheben. Beachte, das einige Kabel vor der Anzeige verlaufen, du musst sie erst zur Seite schieben.
