Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 10
Removing the metal cover will expose the odometer. Inspect the various plastic gears for broken parts. If you find any, they will need to be fixed before continuing. Removing the metal cover will expose the odometer. Inspect the various plastic gears for broken parts. If you find any, they will need to be fixed before continuing. Removing the metal cover will expose the odometer. Inspect the various plastic gears for broken parts. If you find any, they will need to be fixed before continuing.
  • Removing the metal cover will expose the odometer. Inspect the various plastic gears for broken parts. If you find any, they will need to be fixed before continuing.
Wenn die Metallabdeckung weg ist, wird der Kilometerzähler sichtbar. Untersuche die Zahnräder, ob ein Zahn abgebrochen ist. In diesem Fall muss das zuerst repariert werden.
