Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 13
This brass gear is the item we are interested in. It is attached to a shaft that is responsible for turning the main odometer gear. This grey gear is the main odometer gear that turns the small plastic gears along the top of the odometer numbers. This is the other end of the shaft the brass gear is attached to. It is held in place by a tight fitting brass ring.
  • This brass gear is the item we are interested in. It is attached to a shaft that is responsible for turning the main odometer gear.
  • This grey gear is the main odometer gear that turns the small plastic gears along the top of the odometer numbers.
  • This is the other end of the shaft the brass gear is attached to. It is held in place by a tight fitting brass ring.
An diesem Messingzahnrad sind wir interessiert. Es ist an der Welle befestigt, welche vom Hauptzahnrad angetrieben wird.
Dieses graue Zahnrad ist der Hauptantrieb, welches die kleinen Plastikzahnräder oben an den Zifferrollen antreibt.
Das ist das andere Ende der Welle mit dem Messingzahnrad. Es ist in einem eng sitzenden Messingring gelagert.
