Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 15
As soon as the metal shaft with the brass gear becomes loose, chase it out with an appropriately sized drill bit. Go slowly to make sure you don't leave too much space between the shaft and the bit or else one of the numbers might fall out of alignment.
  • As soon as the metal shaft with the brass gear becomes loose, chase it out with an appropriately sized drill bit. Go slowly to make sure you don't leave too much space between the shaft and the bit or else one of the numbers might fall out of alignment.
Sobald die Welle mit dem Messingzahnrad lose ist, drücke sie mit einem Bohrer mit passendem Durchmesser ganz heraus. Drücke langsam, so dass kein großer Zwischenraum zwischen Bohrer und Welle entsteht. Die Ziffernrollen könnten sonst aus der Reihe rutschen und herausfallen.
