Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 4 übersetzen
Schritt 4
Pull up the bottom side of the keyboard and locate the ribbon connecting the keyboard to the motherboard. Locate the blue end of the ribbon which is connected to the motherboard. Lift up the black flap on the connector and gently pull the ribbon away from the connector  which is parallel to the motherboard.
  • Pull up the bottom side of the keyboard and locate the ribbon connecting the keyboard to the motherboard.
  • Locate the blue end of the ribbon which is connected to the motherboard.
  • Lift up the black flap on the connector and gently pull the ribbon away from the connector which is parallel to the motherboard.
  • Lift the keyboard up and off of the motherboard. Detach the blue end of the ribbon from the connector.
Hier Übersetzung einfügen
