Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
Locate the yellow tabbed pin strip which is directly next to the original location of the red tabbed pin strip. Disconnect the yellow tabbed pin strip from the motherboard using the same technique used to disconnect the red tabbed pin strip in the previous step. Disconnect the yellow tabbed pin strip from the motherboard using the same technique used to disconnect the red tabbed pin strip in the previous step.
  • Locate the yellow tabbed pin strip which is directly next to the original location of the red tabbed pin strip.
  • Disconnect the yellow tabbed pin strip from the motherboard using the same technique used to disconnect the red tabbed pin strip in the previous step.
Hier Übersetzung einfügen
