Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 2
First pry the left side of the cover off, then pry the right side of the cover off before removing. Trying to pry the cover off from only one side will result in breaking the plastic tabs. First pry the left side of the cover off, then pry the right side of the cover off before removing. Trying to pry the cover off from only one side will result in breaking the plastic tabs.
Remove bottom cover
  • First pry the left side of the cover off, then pry the right side of the cover off before removing. Trying to pry the cover off from only one side will result in breaking the plastic tabs.
Heble zuerst links, dann rechts und löse die Abdeckung. Du musst abwechselnd auf beiden Seiten arbeiten, wenn du nur von einer Seite hebelst brechen die Plastikklammern innen.
