Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 13 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 5 übersetzen
Schritt 5
Lift the display up from the frame and remove it from the iMac. It may be necessary to slowly lift from one side, to peel against the remaining adhesive. Be very careful handling the display—it's big, heavy, and made of glass.
  • Lift the display up from the frame and remove it from the iMac.
  • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
  • Be very careful handling the display—it's big, heavy, and made of glass.
  • During reassembly, head over to our display adhesive guide to install the new adhesive.
Hebe das Display nach oben aus dem Rahmen und entferne es aus dem iMac heraus.
Möglicherweise musst du an einer Seite anfangen, das Display langsam anzuheben, um den Rest des Klebebandes zu lösen.
Sei vorsichtig bei der Handhabung des Displays. Es ist groß, schwer und aus Glas.
[* black] Lift the display up from the frame and remove it from the iMac.
[* black] It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
[* icon_caution] Be very careful handling the display—it's big, heavy, and made of glass.
[* icon_reminder] During reassembly, head over to our [guide|137411|display adhesive guide] to install the new adhesive.
