Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 5 übersetzen
Schritt 5
If you've gotten here, you most likely have an issue with your GPU due to this recall: Dell Blog Post about NVIDIA GPU Recall
GPU Reflow
  • If you've gotten here, you most likely have an issue with your GPU due to this recall: Dell Blog Post about NVIDIA GPU Recall
  • To fix this, you can try to "re-flow" the soldier on the motherboard, which should give you a little more life out of the laptop.
  • Follow this guide to remove your motherboard: D820 Motherboard Removal
  • Once you have remove the motherboard, clean off all of the thermal paste from the two remaining chips, one NVIDIA GPU, and another Intel.
  • Also remove all stickers, foam, and plastic from the motherboard, as they will melt or catch fire in the next step
  • Pre-heat your oven to 395 degrees Farenheight.
  • Place the motherboard on a sheet of foil, on a baking sheet. Place into the oven for 10 minutes. Then remove and let cool
  • Re-assemble laptop following motherboard steps in reverse.
Hier Übersetzung einfügen
