Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 7
Insert the pointed end of the a spudger between the protective tape and the inverter board. Carefully pull up with the spudger to lift the inverter board out enough to access the connector cables.
  • Insert the pointed end of the a spudger between the protective tape and the inverter board.
  • Carefully pull up with the spudger to lift the inverter board out enough to access the connector cables.
  • Once you can easily grab the board, pull it up enough to gain access to the inverter board's output connector.
  • Gently remove the board in order to avoid damaging any wires or connectors.
Hier Übersetzung einfügen
