Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws. Carefully slide and pull the two parts of the controller shell apart, exposing the innards. Try not to move the joystick when reassembling. This will almost assuredly break your alignment. The less the joystick is moved, the easier it will be to realign the joystick to the pots.
Opening up the controller
  • Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
  • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
  • Try not to move the joystick when reassembling. This will almost assuredly break your alignment. The less the joystick is moved, the easier it will be to realign the joystick to the pots.
Hier Übersetzung einfügen
