Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3
To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port. Note: the connection lifts up to remove.
Disconnect Battery
  • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
  • Note: the connection lifts up to remove.
Um den Akku zu entfernen musst du zunächst z.B. mit einer Pinzette den Anschluss lösen.
Der Verbinder muss nach oben gezogen werden.
[title] Disconnect Battery
-[* black] To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
-[* icon_note] Note: the connection lifts up to remove
+[* red] To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
+[* icon_note] Note: the connection lifts up to remove.
