Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 9 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward. The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons. The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
  • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
Hier Übersetzung einfügen
