Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 8
Slowly and gently lift the top edge of the front panel assembly away from the steel inner frame. Continue to rotate the front panel assembly away from the steel inner frame until it slowly begins to peel off the adhesive applied below the home button area.
  • Slowly and gently lift the top edge of the front panel assembly away from the steel inner frame.
  • Continue to rotate the front panel assembly away from the steel inner frame until it slowly begins to peel off the adhesive applied below the home button area.
  • It may be easiest to insert a spudger at the top and work it around the edges, spreading gently as you go.
  • Carefully pull the lower edge of the front panel assembly away from the steel inner frame.
  • Be careful, if the home button sticks to the front panel you may tear the home button cable.
  • Do not pull the front glass completely away from the frame. Doing so may result In damage to the digitizer cable.
  • If the glass is cracked (which it probably is since you're replacing it) removing the panel is likely to cause it to bend, kicking off small shards of glass. Before you do this step, cover the front with clear tape, then perform the actual removal over a trash can. Protective eyewear would also be prudent.
Hebe die obere Kante der Front Panel Einheit vorsichtig von dem inneren Stahlrahmen herunter.
Rotiere die Front Panel Einheit weiter von dem inneren Stahlrahmen weg, bis sie sich langsam vom Kleber unter dem Home Button Bereich löst.
Möglicherweise hilft es auch, einen Spudger oben einzuführen, damit um die Ecken zu fahren und dabei den Abstand zu vergrößern.
Ziehe vorsichtig die untere Kante der Front Panel Einheit von dem inneren Stahlrahmen weg.
Sei vorsichtig: Wenn der Home Button am Front Panel kleben bleibt, kann das Home Button Kabel reißen.
Ziehe das Frontglas nicht vollständig vom Rahmen weg. Andernfall kann das in einem Schaden am Digitizer Kabel resultieren.
Wenn das Glas gesprungen ist (was vermutlich der Fall ist), kann das Panel sich beim Entfernen biegen, wodurch kleine Glassplitter umherfliegen können. Bevor du diesen Schritt durcharbeitest, bedecke die Frontseite mit durchsichtigem Tape und entferne das Front Panel über einem Mülleimer. Es ist ratsam, die Augen zu schützen.
