Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 15
Use the flat end of a spudger to begin peeling the Lightning connector cable assembly up from the rear case. Use the flat end of a spudger to begin peeling the Lightning connector cable assembly up from the rear case. Use the flat end of a spudger to begin peeling the Lightning connector cable assembly up from the rear case.
  • Use the flat end of a spudger to begin peeling the Lightning connector cable assembly up from the rear case.
Löse mit dem flachen Ende eines Spudgers das Kabel der Lightning Connector Einheit leicht aus dem Gehäuse.
