Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 3
Use a heat gun to loosen the adhesive between the display and frame.
  • Use a heat gun to loosen the adhesive between the display and frame.
  • Start with the heat gun far away from your hand. Then, slowly move your hand towards the heat gun until the air is warm, but not hot.
  • At this set distance, slowly warm the entire front of the phone.
  • The heat gun can be dangerous to you and to the phone. Avoid placing your hand too close to the end of the gun, as it can burn you. Also avoid heating the bottom plastic panel of the phone because it can melt when exposed to direct heat.
Hier Übersetzung einfügen
