Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3
Repeat for the second strip. Hold down the battery as you remove the second strip, or the strip may fling the battery when it separates from the case. If the adhesive breaks off underneath the battery and can't be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
  • Repeat for the second strip.
  • Hold down the battery as you remove the second strip, or the strip may fling the battery when it separates from the case.
  • If the adhesive breaks off underneath the battery and can't be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
  • Wait about one minute for the alcohol solution to weaken the adhesive. Use the flat end of a spudger to gently lift the battery.
  • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
  • Do not pry against the logic board or you may damage the phone.
  • Do not insert the spudger in the area between the volume down (-) button and the top edge of the battery, or you may damage the volume control cable lying underneath.
  • For more alternative methods when either of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
Wiederhole für den zweiten Streifen.
Drücke den Akku nach unten, während du den zweiten Streifen entfernst, er könnte sonst den Akku heraus schleudern, wenn er sich vom Gehäuse löst.
Wenn der Klebestreifen abgerissen ist und nicht herausgeholt werden kann, dann tröpfle ein wenig hochkonzentrierten Isopropylalkohol (mehr als 90%ig) an die Stelle mit dem gerissenen Klebeband unter die Kante des Akkus.
Lasse den Alkohol etwa eine Minute lang einwirken, bis der Kleber weich ist. Hebe dann den Akku vorsichtig mit dem flachen Ende des Spudgers hoch.
Versuche nicht, den Akku mit Gewalt herauszuhebeln. Tröpfle mehr Alkohol hinein, falls das nötig ist, um den Kleber zu schwächen. Verforme niemals den Akku und stich ihn nicht an.
Heble nicht gegen das Logic Board, das iPhone könnte beschädigt werden.
Schiebe die Karte nicht im Bereich zwischen der oberen Kante des Akkus und dem Lautstärkeregler (-) ein, sonst riskierst du, das Lautstärkekontrollkabel zu beschädigen, das direkt unter dem Akku in das Rückgehäuse geklebt ist.
Wenn einer der beiden Klebestreifen gerissen ist, kannst du auch eine der Alternativmethoden aus nachfolgendem Schritt benutzen.
