Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Pull the volume control buttons by the metal bar to remove them from the rear case. The buttons are held to the case with an adhesive gasket, pull carefully to prevent ripping the membrane. The buttons are held to the case with an adhesive gasket, pull carefully to prevent ripping the membrane.
  • Pull the volume control buttons by the metal bar to remove them from the rear case.
  • The buttons are held to the case with an adhesive gasket, pull carefully to prevent ripping the membrane.
Ziehe die Lautstärkeregler an der Metallleiste aus dem Gehäuse.
Die Buttons sind mit einer Klebedichtung am Gehäuse befestigt, sei vorsichtig, damit du die Membran nicht zerreißt.
