Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Before disassembly, ensure that the boombox is powered off, unplugged and any batteries have been removed from the device.
Remove Bottom Shell
  • Before disassembly, ensure that the boombox is powered off, unplugged and any batteries have been removed from the device.
  • Begin by turning the boombox over so that the bottom is facing up.
  • When turning the boombox over, the antenna will be pointing down. Take care that the antenna is not damaged when opening the device.
  • Your boombox will have a total of 12 Phillips screws on the bottom. The location of the screws needed to remove the bottom panel are circled in red in the image to the left.
  • Remove the 12 screws with a Phillips head screwdriver on the bottom panel.
  • One screw, in the upper left corner, does not need to be removed to disassemble the device. This screw is for the antenna.
Hier Übersetzung einfügen
