Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
With all 12 screws removed, it is possible to detach the plastic bottom cover from the top half of the boombox.
  • With all 12 screws removed, it is possible to detach the plastic bottom cover from the top half of the boombox.
  • Push the bottom shell back slightly before pulling it up. The plastic bottom will lift up directly but there is a lip that fits under the black handle that must first be exposed, as seen in the image on the left.
  • The boombox's antenna must be straight in order for the bottom cover to be pulled up.
  • Several wires run between the bottom half and top half of the boombox. Take care not to damage or otherwise tear the wiring when opening the device.
Hier Übersetzung einfügen
