Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
After removing the circuit board, position the board in a way that allows you to access the solder connections on the back.
  • After removing the circuit board, position the board in a way that allows you to access the solder connections on the back.
  • Using a soldering iron, heat and remove the wire from each of the five connections located in the box to the left.
  • Please note the order of the wires to their position on the circuit board for reassembly.
  • Make sure all of the solder is completely removed from the five connections so an electrical short will not occur after reassembly.
Hier Übersetzung einfügen
