Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 7 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard. Pry up the motherboard cover to open the plastic clips which hold the cover in its place. The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
  • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
  • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
  • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
  • Work your way along the right edge.
Hier Übersetzung einfügen
