Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 17 übersetzen
Schritt 17
Route the wiring in the same manner the old switch wiring was routed, insert the switch into the steering column, and put back the ignition switch cover and screws. Use the electrical tape to corral any of the loose wiring. Put all paneling back the way it was by following the above directions in reverse. Make sure that the rubber O-ring around the ignition switch is properly seated against the switch when putting back the lower steering wheel cover.
  • Route the wiring in the same manner the old switch wiring was routed, insert the switch into the steering column, and put back the ignition switch cover and screws.
  • Use the electrical tape to corral any of the loose wiring. Put all paneling back the way it was by following the above directions in reverse. Make sure that the rubber O-ring around the ignition switch is properly seated against the switch when putting back the lower steering wheel cover.
Hier Übersetzung einfügen
