Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 3
Using a plastic opening tool, release the latch (it swings up towards the cable) and slide the digitizer connector free.
Disconnect and Remove the Digitizer Connector
  • Using a plastic opening tool, release the latch (it swings up towards the cable) and slide the digitizer connector free.
  • On the wide area of the cable (where the chip is), the cable is strongly glued to a small metal plate which is in turn strongly affixed to the back with heat-conducting adhesive. Loosen this cable from the back.
  • If you plan on reusing the digitizer be very careful when removing this as you can easily damage the cable. Use gentle applications of heat and a metal tool to pry between the metal plate and the back.
Hier Übersetzung einfügen
