Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Begin the process by making sure that the dock is disconnected and the power is turned off. Start by using the plastic opening tool on the side opposite the dock/ charging port. Begin to open the device along the short sides of the tablet. When you have reached the side with the charging/ dock port be gentle with the opening tool due to the thinner plastic that could be broken with excessive force.
Back Panel Removal
  • Begin the process by making sure that the dock is disconnected and the power is turned off.
  • Start by using the plastic opening tool on the side opposite the dock/ charging port. Begin to open the device along the short sides of the tablet.
  • When you have reached the side with the charging/ dock port be gentle with the opening tool due to the thinner plastic that could be broken with excessive force.
  • Once the opening tools have completely made their way around the device use the spudger to separate the back panel from the screen and expose the inside.
Hier Übersetzung einfügen
