Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 11 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 8
Lift the black plastic flap attached to the display data cable retainer and rotate it toward the DC-In side of the MacBook. Pull the display data cable out of its socket. The display data cable socket is very fragile. Do not lift the connector upward as you disconnect it, as the socket may break off the logic board. Pull the cable parallel to the face of the logic board.
  • Lift the black plastic flap attached to the display data cable retainer and rotate it toward the DC-In side of the MacBook.
  • Pull the display data cable out of its socket.
  • The display data cable socket is very fragile. Do not lift the connector upward as you disconnect it, as the socket may break off the logic board. Pull the cable parallel to the face of the logic board.
Hier Übersetzung einfügen
