Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 6
Remember to peel up the digitizer flex cable, as it is glued to the proximity sensor, and might cause damage when removing the front panel, should you forget it.
  • Remember to peel up the digitizer flex cable, as it is glued to the proximity sensor, and might cause damage when removing the front panel, should you forget it.
  • The flex cable is held down with a bit of adhesive, just use your spudger to carefully peel it up.
Hier Übersetzung einfügen
