Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 5
Before going any further, test your new screen by plugging it to the device's main flex and powering it on. If all is well, power off. If not, contact your screen reseller. Carefully remove the earpiece from screen, by pulling on it gently and separating the adhesive. Notice the position of the earpiece on the back of the screen, as you will need to put it back in the same position on the new screen. Ideally, remove the earpiece with its adhesive, as you will need to put the earpiece back on the new screen when you reassemble the device. Earpiece adhesive keeps the earpiece properly in place on the screen.
Prepare for new screen assembly
  • Before going any further, test your new screen by plugging it to the device's main flex and powering it on. If all is well, power off. If not, contact your screen reseller.
  • Carefully remove the earpiece from screen, by pulling on it gently and separating the adhesive. Notice the position of the earpiece on the back of the screen, as you will need to put it back in the same position on the new screen.
  • Ideally, remove the earpiece with its adhesive, as you will need to put the earpiece back on the new screen when you reassemble the device. Earpiece adhesive keeps the earpiece properly in place on the screen.
  • Make sure the earpiece is in the right position and connects properly with the main flex before you reassemble for good. Otherwise you will not get sound from the earpiece, and won't be able to make calls normally.
Teste zunächst deinen neuen Bildschirm. Schließe ihn an das Hauptflexkabel an und schalte das Smartphone ein. Wenn alles funktioniert, kannst du ihn wieder abschalten, sonst musst du dich an den Verkäufer des Bildschirms wenden.
Löse vorsichtig den Ohrhörer-Lautsprecher aus der Klebeverbindung zum Bildschirm, indem du ihn vorsichtig abziehst. Merke dir seine genaue Position auf der Rückseite des Bildschirms, du musst ihn genauso auf dem neuen Bildschirm festkleben.
Idealerweise entfernst du den Ohrhörer-Lautsprecher mit seinem Kleber, da du ihn ja am neuen Bildschirm wieder festkleben musst, wenn du das Gerät wieder zusammenbaust. Durch Klebstoff bleibt der Ohrhörer-Lautsprecher an seinem Platz.
Bevor du das Gerät wieder endgültig zusammenbaust, musst du sicher sein, dass der Ohrhörer-Lautsprecher korrekt sitzt und richtig angeschlossen ist. Ansonsten wirst du nichts hören und nicht richtig telefonieren können.
