Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
Using the flat end of a spudger, pry the left speaker out of its socket on the front bezel. De-route the speaker cable along the top edge of the screen. Work carefully and slowly, holding onto the wire and not the speaker itself. The solder joints may break if pulled on too hard.
  • Using the flat end of a spudger, pry the left speaker out of its socket on the front bezel.
  • De-route the speaker cable along the top edge of the screen.
  • Work carefully and slowly, holding onto the wire and not the speaker itself. The solder joints may break if pulled on too hard.
  • In the same manner described above, remove the right speaker from its socket on the front bezel.
  • Place both speakers on the back of the upper LCD.
Hier Übersetzung einfügen
