Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 7
In the following steps, you will be using a spudger to remove the hinge pin from the left side of the DSi XL. Place the tip of a spudger in the LED diffuser compartment, on the face of the clutch hinge. Push the clutch hinge to the left.
  • In the following steps, you will be using a spudger to remove the hinge pin from the left side of the DSi XL.
  • Place the tip of a spudger in the LED diffuser compartment, on the face of the clutch hinge.
  • Push the clutch hinge to the left.
  • Some force will be required. You will hear an audible "pop" when the clutch has cleared the lower case. It will move about 0.25".
Hier Übersetzung einfügen
