Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 8
Lift the left side of the front bezel away from the upper case. Do not lift too far, or else the hinge pin will break. Only lift enough to clear the LED compartment, about 1".
  • Lift the left side of the front bezel away from the upper case.
  • Do not lift too far, or else the hinge pin will break. Only lift enough to clear the LED compartment, about 1".
  • Pull the front bezel to the left, separating the front bezel from the upper case.
  • Do not attempt to fully separate the two halves yet. There are still ribbon cables running through the upper case.
Hier Übersetzung einfügen
