Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 10
In order to remove the upper LCD and the cameras from the front bezel, it is helpful to coil the ribbon cables together. Carefully coil the two ribbon cables together, so that the connectors are on the inside of the spool.
  • In order to remove the upper LCD and the cameras from the front bezel, it is helpful to coil the ribbon cables together.
  • Carefully coil the two ribbon cables together, so that the connectors are on the inside of the spool.
  • Wrap the ribbon cables tightly, but not too tight, as bending the connectors will render them inoperable.
Hier Übersetzung einfügen
