Schritt 7 übersetzen
Schritt 7
Desolder Motors from Flight Controller
Use a soldering iron and solder wick to desolder the four motors from the control board.
If the connection holds even after removing the solder from the joint, gently pull up on the wire while applying heat to the joint until the wire separates from the PCB.
