Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 6
Pull back on the air filter case in order to expose the other end of the hose, hidden underneath the front edge of the air cleaner assembly. You'll probably want another set of hands to help you with this. If you are having difficulty working in the limited space, you can remove the air cleaner assembly completely for better access.
  • Pull back on the air filter case in order to expose the other end of the hose, hidden underneath the front edge of the air cleaner assembly.
  • You'll probably want another set of hands to help you with this. If you are having difficulty working in the limited space, you can remove the air cleaner assembly completely for better access.
  • Use the channel locks again to remove the clamp securing the hose to the radiator.
Hier Übersetzung einfügen
