Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them Use your Phillips head #0 to remove the one - 7mm bottom center screw Use your Phillips head #2 to remove the two - 8mm screws by the handle
  • The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them
  • Use your Phillips head #0 to remove the one - 7mm bottom center screw
  • Use your Phillips head #2 to remove the two - 8mm screws by the handle
  • Push down the two release points to pull the plastic piece up
  • Pull the plastic piece up
Hier Übersetzung einfügen
