Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Once you have removed the back cover, battery, daughterboard, motherboard, and speakers, the LCD assembly will remain.
  • Once you have removed the back cover, battery, daughterboard, motherboard, and speakers, the LCD assembly will remain.
  • Depending on your replacement, you may need to separate the housing frame from the LCD/digitizer.
  • To remove the LCD/digitizer, carefully heat the edge with a heat gun and use a thin blade to separate from the adhesive. Go slowly, and heat often, as the glass cracks very easily. Work around all of the edges and carefully pull the LCD/digitizer from the housing.
Hier Übersetzung einfügen
