Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 5 übersetzen
Schritt 5
Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves. The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
Blade Button Removal
  • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
  • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
Hier Übersetzung einfügen
