Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Remove both 6 mm screws from the clip side of the camera. After you have removed the two screws, remove both the clip and the plate behind the clip so that the inside of the camera is exposed.
Clip Side Repair
  • Remove both 6 mm screws from the clip side of the camera.
  • After you have removed the two screws, remove both the clip and the plate behind the clip so that the inside of the camera is exposed.
  • If one of more of the clips appear to be broken, the back plate might need to be replaced.
Hier Übersetzung einfügen
