Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Using the spudger, create space between the speaker covers and then remove. On the underside of the device, remove the rubber stand with the BeatsPill logo on it. Using an ESD-safe Phillips #0 screwdriver, remove the four screws that were underneath the rubber stand.
Removing the Case Screws
  • Using the spudger, create space between the speaker covers and then remove.
  • On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
  • Using an ESD-safe Phillips #0 screwdriver, remove the four screws that were underneath the rubber stand.
Setze einen Spudger unter die Lautsprecherabdeckungen, erzeuge einen kleinen Spalt und entferne sie dann
Entferne an der Unterseite den Gummifuß mit dem Beats Pill Logo.
Unter dem Gummifuß befinden sich vier Kreuzschlitzschrauben #0. Drehe sie heraus.
[title] Removing the Case Screws
-[* red] Using the spudger, create space between the speaker covers and then remove.
-[* orange] On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
-[* yellow] Using a ESD-safe Philips #0 Screwdriver, remove the four screws that were underneath the rubber stand.
+[* black] Using the spudger, create space between the speaker covers and then remove.
+[* black] On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
+[* red] Using an ESD-safe Phillips #0 screwdriver, remove the four screws that were underneath the rubber stand.
