Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3
Use the spudger to pry the device apart along its seam, starting in the middle. Open the device to separate the front and back panels. Open the device to separate the front and back panels.
Separate the Device
  • Use the spudger to pry the device apart along its seam, starting in the middle.
  • Open the device to separate the front and back panels.
Benutze einen Spudger und beginne in der Mitte mit dem Trennen der Gehäusenaht.
Zerlege das Gerät in zwei Gehäuseteile. Es sollte dann wie in Bild 3 aussehen.
[title] Separate the Device
-[* red] Using the spudger, starting in the middle, pry the device apart along it’s seam as circled in red.
-[* orange] Open the device to separate the two main bodies of the device. The device should look as picture number 3.
+[* black] Use the spudger to pry the device apart along its seam, starting in the middle.
+[* black] Open the device to separate the front and back panels.
