Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 5
Ensure you have thoroughly heated the adhesive before attempting to pry the screen off. Do NOT press on the back of the phone while attempting to lift the screen. This will create cracks in the glass.
Use an Opening Pick to Pry Off the Screen
  • Ensure you have thoroughly heated the adhesive before attempting to pry the screen off.
  • Do NOT press on the back of the phone while attempting to lift the screen. This will create cracks in the glass.
  • At the bottom of the touch screen, under the menu buttons, there are connections that can be easily broken. When taking the adhesive off the bottom section, work carefully to prevent damage.
  • Slide opening pick around perimeter of the glass. Make sure not to push edge too far under the screen.
Hier Übersetzung einfügen
