Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 4 übersetzen
Schritt 4
Use the plastic opening tool to remove both components of the front panel. This includes the black part on the outside of the front panel and the main silver panel. Once every screw and panel is removed, you can replace the backplate to make your camera weatherproof again. Once every screw and panel is removed, you can replace the backplate to make your camera weatherproof again.
Front Panel
  • Use the plastic opening tool to remove both components of the front panel. This includes the black part on the outside of the front panel and the main silver panel.
  • Once every screw and panel is removed, you can replace the backplate to make your camera weatherproof again.
Hier Übersetzung einfügen
