Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
After you have removed the latch, open the compartment door to remove the battery.
  • After you have removed the latch, open the compartment door to remove the battery.
  • The batteries contain highly acidic contents. If the battery has leaked or ruptured while inside the compartment, there may be damage to the camera's circuitry. Carefully clean out any residue from the battery using latex gloves and tissues.
  • If the compartment door is loose, check the hinge or the locking pieces under the rubber pad. To do this, unscrew and remove the rubber and metal plate on the door.
Hier Übersetzung einfügen
