Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 6
Use the 14 mm socket wrench to loosen the oil drain plug. After a few turns, use your hands to loosen the plug until it is off. Oil contents may be hot if the car has been running recently! Allow the oil to completely drain into the pan.
  • Use the 14 mm socket wrench to loosen the oil drain plug. After a few turns, use your hands to loosen the plug until it is off.
  • Oil contents may be hot if the car has been running recently!
  • Allow the oil to completely drain into the pan.
  • Look for small, shiny specks in the oil. The specks could be metal flakes from the engine and may be a sign of a serious problem with the engine. Take your car in for maintenance if you see these shiny specks.
  • Use a rag to wipe around the opening for any remnants of the oil.
  • After the oil has drained, screw the oil drain plug back onto the car. Hand tighten as much and use a 14 mm socket wrench to tighten about a half turn more.
  • Do not overtighten! This could lead to cracking the oil pan.
Hier Übersetzung einfügen
