Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 7
Locate the oil filter from either above or below the car (The images are from above). The oil filter is located below the engine and aligned horizontally, facing the front of the car. Place the oil drain pan under the filter.
  • Locate the oil filter from either above or below the car (The images are from above).
  • The oil filter is located below the engine and aligned horizontally, facing the front of the car.
  • Place the oil drain pan under the filter.
  • Unscrew the filter by hand. Turn the filter counterclockwise if looking at the filter from the front.
  • If the filter is too hard to loosen, use either some pliers or an oil filter wrench.
  • Wipe around the area where the filter was settled.
  • Make sure the washer part of the filter comes off. If left on with the new filter, the seal may be broken and can lead to a leak.
Hier Übersetzung einfügen
