Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 6 übersetzen
Schritt 6
Fine tune the derailleur by tightening or loosening the barrel adjuster screw. Loosening this screw causes the derailleur to move slightly towards a larger sprocket, while tightening it moves the derailler towards a smaller sprocket.
  • Fine tune the derailleur by tightening or loosening the barrel adjuster screw. Loosening this screw causes the derailleur to move slightly towards a larger sprocket, while tightening it moves the derailler towards a smaller sprocket.
  • Shift through each gear while pedaling. The derailleur should move the chain one gear over each time you shift up or down.
  • If the chain skips or makes noise when you are not shifting, use the barrel adjustment screw to fine tune the derailleur alignment.
  • Repeat the previous steps until the derailleur shifts smoothly and makes a minimal amount of noise.
Hier Übersetzung einfügen
