Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 16
Remove the final screw holding the motherboard in place. Then gently lift the motherboard up vertically. Remove the two marked cables. These will be tight. Do not pull by the wires. Carefully wiggle the connectors only. Remove the final data cable near the front of the system board. The motherboard will be free. Lift up and towards the left to remove from the base.
  • Remove the final screw holding the motherboard in place. Then gently lift the motherboard up vertically.
  • Remove the two marked cables. These will be tight. Do not pull by the wires. Carefully wiggle the connectors only.
  • Remove the final data cable near the front of the system board. The motherboard will be free. Lift up and towards the left to remove from the base.
Hier Übersetzung einfügen
