Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Schritt 10 übersetzen
Schritt 10
The LCD needs to be removed to proceed. Start by disconnecting the marked cable from its socket and disconnecting the cables from their clips in the palm rest.
Proceed to pull the two WiFi antenna cables through the motherboard.
Remove the screws that hold each LCD hinge cover in place. There is 1 screw for each cover.
Gently pry each cover off its hinge.
