Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 19 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3
Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi. Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing. Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
  • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
  • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
Hier Übersetzung einfügen
