Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 7 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Turn the laptop upside down so that the underside of the laptop is facing you. Use a Phillips #000 screwdriver to unscrew the  4.3 mm screws located on the edges and corners of the laptop. Use a Phillips #000 screwdriver to unscrew the  4.3 mm screws located on the edges and corners of the laptop.
  • Turn the laptop upside down so that the underside of the laptop is facing you.
  • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
Hier Übersetzung einfügen
